Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
SirAndy |
Jun 29 2020, 12:25 PM
Resident German Group: Admin Posts: 41,636 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
BillC |
Jul 1 2020, 04:12 PM
Thanks! So do I. Well, it's finally time to put up or shut up. Up 'til now, I've been complaining about what has been done to the car over the years, now it's time to actually do something about it. Sunday, we pulled the engine and trans from the car. Monday, I spent time removing more stuff from the car. Yesterday, I pushed the engine-less car out of the garage and hosed out as much dirt as I could from the frunk, the gas tank area and under the rear trunk. No pictures of any of this, figured it was kinda boring and yesterday was quite soggy. Today is the start of the metal repairs. I started with the holes in the divider panel between the gas tank and the frunk. Here's what it looked like to start: To start, I cut out the "web" between the holes, to make one large hole, which seemed easier to patch than 3 smaller holes. Then, I put a piece of cardboard behind the hole and used a pencil to outline out a patch. I cut out the cardboard, traced it on a piece of sheet metal and then cut out the piece of metal. Here's a pic of the patch tacked in place. Then I got to work, welding and grinding. Here are a couple of pics of the patch installed and cleaned up (outside and inside): And, with a coat of primer: It seemed appropriate to use the primer that I won at Octeenerfest three years ago: |
Lo-Fi Version | Time is now: 14th May 2024 - 08:34 AM |
