Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 2 2020, 05:19 PM
Made more progress today.
Removed the rear window and the engine deck lid. Found another thing that needs to be fixed -- apparently they stripped out the nut for the deck lid mount, so they drilled it out and dropped a bolt in from above. Was originally thinking of just putting a helicoil in to fix the welded nut, but it may have been drilled out too large for that, will measure tomorrow. Welded up the holes in the firewall, Also wirebrushed the rusty areas on the firewall and the window mounting area. Treated the rust with Loctite Rust Converter, which will get primered and painted after it dries. Also, the touch-up paint finally arrived from Paintscratch.com (we're having UPS problems). So, I touched up the frunk and gas tank areas. Looking much better: |
Lo-Fi Version | Time is now: 13th May 2024 - 11:40 PM |
