Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
Montreal914 |
Jul 2 2020, 05:50 PM
Senior Member Group: Members Posts: 1,556 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Not sure what your front sway bar setup is but I don't see any reinforcement plate on the inner wall, is it mounted on the wheel well side? Or was the factory installed sway bar didn't have the added plate? (IMG:style_emoticons/default/confused24.gif)
BillC |
Jul 2 2020, 05:53 PM
Not sure what your front sway bar setup is but I don't see any reinforcement plate on the inner wall, is it mounted on the wheel well side? Or was the factory installed sway bar didn't have the added plate? (IMG:style_emoticons/default/confused24.gif) It's a factory-installed sway bar, so no added plate on the inside. The mounting plates are spot-welded on the outside with multiple spots. |
Lo-Fi Version | Time is now: 14th May 2024 - 02:15 PM |
