Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 3 2020, 04:44 PM
It doesn't seem like I accomplished much today, but it took all day to do it.
I installed a new retractable antenna. Had to leave the old antenna base grommet, since the area of affected paint is larger than the new base. Then, I removed the windshield wiper assembly. I cleaned up and treated the rust around the wiper post holes. Then, I disassembled the wiper assembly and cleaned and greased the posts. Hopefully, tomorrow I'll be able to paint around the post holes and then Sunday I'll be able to reinstall the wiper assembly. I also installed new hoses for the window washers, while I have easy access under the cowl. At some point, I'll install an electric pump for the washer. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:36 PM |
