Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 9 2020, 07:08 PM
The order with the rubber isolator finally came, so I installed the wiper motor and wipers.
The hardest part of the installation is the nut for the other end of the isolator. It hides under the dash, and is very difficult to reach with the dash in place. Fortunately, if you take out the ashtray mount (two phillips screws and push forward to unclip), you can just barely get access with a 1/4" drive deep socket (10mm) and a universal joint. The red circle shows the inside nut. |
Lo-Fi Version | Time is now: 14th May 2024 - 03:33 PM |
