Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 11 2020, 04:19 PM
Today I worked on reinstalling the fresh air box. With a new top gasket and intake screen (came on '74 and later 914s), it was every bit the royal pain that they said it was. But, here is the box installed:
Because it was such a pain to get the two bolts installed, I had to get creative. I got the driver-side bolt in okay, but couldn't get the box high enough to get the passenger-side bolt in. So, I decided to make a "mini jack" with a tall socket and a brake pad spreader. This got it up high enough to get the last bolt in. Then, I connected the cable to the fan box. This was almost as big a pain as installing the box itself. No pics, since I had to do the job basically by feel. Then, the hoses were reinstalled. First the paper hoses to the ventilation system and then the drain hoses. One of the old hoses broke, so I had to get new hoses (from AA). Unfortunately, they don't quite match the old ones, so I'll order some from 914Rubber, next time I place an order. |
Lo-Fi Version | Time is now: 14th May 2024 - 03:10 PM |
