Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jul 23 2020, 02:11 PM
So, the parts I've been waiting for finally arrived. With the new drain hoses for the fresh air box in hand, I was able to get the tank re-installed.
The drain hoses are held in by ring clips, which have quite a bit of force. I wasn't able to hold them open reliably and safely with any of my existing tools, so I modified a pair of pliers to work. First step was to take them apart, then to mill a slot in each half. The slot was offset from the center-line of the jaws so the clip would fit properly. Here are the pliers reassembled and holding a ring clip. They work very nicely. And, a shot with the tank installed and everything mounted back onto it. It looks a little high, but I made sure everything fits under the hood with clearance. I didn't bother with pics of the installation process, since it's a standard tank being installed in a more-or-less standard car. The only real annoyance was getting the rubber side pieces positioned properly, since it was rather finicky to get them at the right height. |
Lo-Fi Version | Time is now: 14th May 2024 - 05:48 PM |
