Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Aug 23 2020, 06:02 PM
Didn't plan on it taking so long for this next update, but we've gone back to work full time and it's been pretty busy. Plus, family and life have a tendency to get in the way. But anyway, I did make some progress.
I finished grinding and primed the inner quarter, where the battery tray goes: Then I welded a nut into the stand and then pre-drilled it, in preparation for welding: I then welded the stand in place, using the tray as a guide. I also pre-drilled the inner quarter for plug welding the outside edge of the tray. This is what it looks like inside the quarter panel. It's tight in there, but I can get the mig welder nozzle in and make plug welds Because it will be such a pain to paint the underside of the tray and inside the stand after the tray is welded in, I pre-painted the tray and inside the stand. I also drilled the holes for mounting the ECU: Finally, I welded in the tray. Here's the inside of the quarter panel, after welding and undercoating. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:51 AM |
