Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Dec 6 2020, 12:13 PM
And . . . done!
It even works! I need to finish cleaning up and painting this side, then it's on to the other side (joy. (IMG:style_emoticons/default/headbang.gif) ) |
Superhawk996 |
Dec 21 2020, 09:01 AM
914 Guru Group: Members Posts: 5,815 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
And . . . done! No getting off that easy. (IMG:style_emoticons/default/happy11.gif) Do tell . . . . How did you weld the top? I'm assuming MIG with blind point & shoot approach? I've got a similar situation but will need to TIG. I'm really debating about removing the top 1/2 of the pyramid. I want full fresh metal in there but I think it's going to be almost impossible to weld the top. Having said that the welds along bottom and side would be more than enough to provide a functional support. Maybe just seam seal the top and be done with it. (IMG:style_emoticons/default/idea.gif) |
BillC |
Dec 21 2020, 09:32 AM
And I agree: grad school sons are sometimes helpful. Yup, especially when they figure out how to pay for grad school on their own! In this case, he has a research assistant position that includes tuition and pays a stipend that covers room and board. And . . . done! No getting off that easy. (IMG:style_emoticons/default/happy11.gif) Do tell . . . . How did you weld the top? I'm assuming MIG with blind point & shoot approach? I've got a similar situation but will need to TIG. I'm really debating about removing the top 1/2 of the pyramid. I want full fresh metal in there but I think it's going to be almost impossible to weld the top. Having said that the welds along bottom and side would be more than enough to provide a functional support. Maybe just seam seal the top and be done with it. (IMG:style_emoticons/default/idea.gif) As you guessed, I used a MIG welder. I pre-drilled all the rosette holes, then one-at-a-time, positioned the MIG gun over each hole and filled in the spot. I used the goggles from my acetylene torch, since I couldn't get my head in position to see while wearing the welding helmet -- it was a little bright, but much better than no protection at all. I did the top after doing the sides and bottom, so I didn't have to worry about the piece moving while welding. Rather than just seam-sealing the top of your pyramid, maybe you can TIG the sides and bottom and then MIG weld the top like I did. Ugly welds hidden where no one can see should be better than no welds at all. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:25 PM |
