Time to un-DAPO the "new" car, Bad things happened to a nice car |
BillC |
Jun 27 2020, 11:30 AM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
So, I bought a "new" 914 a few weeks ago (a '73 2.0). When I received it from the shipper, I noticed was the seller was quite artful about his pictures, with what was and what wasn't shown. And, now that I've had a chance to start taking things apart, I have uncovered quite a bit of DAPO-done-damage, and I'm sure there's more hiding somewhere (oh boy! something to look forward too....). Some of the damage appears to have been there for a loooong time.
I've already received a piece from a scrap car to fix this hole: Once I took the rockers off, I discovered this: Yes, they hole-sawed through FOUR layers of sheet metal, including the heat duct. Not sure what they were thinking, but there it is. In the trunk, I found three hole-sawed holes. I think they might have been thinking about mounting the fuel pump in a 75/76 blister, but they never finished the work (and also picked the wrong location). |
BillC |
Jan 18 2021, 07:27 PM
I was able to spend more time today on the car, stripping off rusty metal. I got the jackpoint pyramid and tube off. And cut out most of the rust at the bottom of the latch panel; not sure how much more I'll be taking off, but at least a little more.
I also cut out the section where the door latch mounts. I was really hoping to leave that section of the latch panel intact and just fill the little rust holes. Unfortunately, I couldn't get the support piece behind it out without better access; so, out it all came.... Here's what it looks like now: Also, here's what the recessed pyramid area inside the jackpoint looks like: This side is definitely worse than the other side. So, I'm going to make a replacement piece out of some 16ga galvaneal I already have and weld it in. I've left the part in place for now, so I can make a pattern off of it (more masking tape...). It's fairly complex, with four triangular panels and a recessed pocket at the bottom for the jack tube, so it'll end up being two pieces welded together. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:32 PM |
