Yeah - another horn issue - 1973 914 |
dhempy |
Jun 28 2020, 04:55 PM
Newbie Group: Members Posts: 6 Joined: 6-September 04 From: Carlsbad, CA Member No.: 2,698 Region Association: Southern California |
Hello everyone,
I need some help tracking down a horn issue on my '73 914. I have had the car 20 years and can't remember the last time the horns worked. I decided to try to fix the horns before I installed a new JWest fuse box. Troubleshooting procedure 1. Orig horns did not work with 12v - bought new Hella Sharptone Hi/Lo twin horn kit 2. Installed new horns, ran a jumper from pin #30 (relay out) to pin #87 and the horns work. (And they sound great too). Does not work with the horn button yet (Ign on) 3. Ordered a couple new relays (just in case). I manually checked the old one(s) with a 12v small backup battery from my garage door opener connected to pins #85 & #86 on the relay - it clicks then i checked continuity at pins #30 & #87 - all good. Relays work but the horn still does not work (and no clicking at the relay) 4. Here is where I am stuck - pin #86 should have 12v (Ign on) and does not. I have continuity between #86 and fuse #8 but I do not have 12v at fuse 8 with the ignition on. Swapped fuse and checked continuity too on new fuse just to be certain. (IMG:style_emoticons/default/headbang.gif) How is 12v fed to fuse #8? What should I do next? Am I missing something? I want to get this resolved before I throw another variable into the mix by installing the JWest fuse box. All comments about this replacement fuse box are welcome (IMG:style_emoticons/default/biggrin.gif) At least the horns look cool installed |
Lo-Fi Version | Time is now: 17th May 2024 - 09:57 PM |
