Re-Conversion of a '70 914, Patching that Big V8 radiator cutout pt. 1 |
76-914 |
Jun 28 2020, 08:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,488 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The engine is sold. I'll soon have a very fresh 901 w/ an "H" gear for sale as well as some other goodies soon for those planning an SBC conversion. I couldn't do much with this sitting in my garage as it already is stuffed to the max. Therefor I felt it somewhat necessary to sell this before commencing with the re-conversion. I've been silently (yeh, I know; me silent) working in the background for a few months fabricating some items that will be needed. I'll do my best to document things a bit more accurately than the previous conversion. Once again I'll be using the Subaru 6 and Subaru transmission. I've had tremendous success with this platform so I might as well repeat myself. So sit back, bear with me and watch as I stumble along and occasionally embarrass myself. Mistakes are an integral part of my journey. (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
Montreal914 |
Oct 1 2020, 09:24 PM
Senior Member Group: Members Posts: 1,541 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Nice shifter location. (IMG:style_emoticons/default/smile.gif)
How far back from the original one is the new straight up shift level? I am looking into doing this with the stock setup. Probably upgrading to a Rennshift but with a straight up stick. From the 904 side drawing, the shifter is before the steering center point (drawing a vertical line down). The 914/4 or /6 in the center image, is way to the front, as we know. With the bent lever, the movement is much more of an up and down vs. front to back. Last cross section is the 914-8 where the straight up shifter is pretty much in line (vertical) with the steering center point. The 914-8 had a completely different shifter linkage that actually went 90 degrees to the passenger side in front of the seat, then along the passenger long. |
76-914 |
Oct 29 2020, 04:27 PM
Nice shifter location. (IMG:style_emoticons/default/smile.gif) How far back from the original one is the new straight up shift level? I am looking into doing this with the stock setup. Probably upgrading to a Rennshift but with a straight up stick. From the 904 side drawing, the shifter is before the steering center point (drawing a vertical line down). The 914/4 or /6 in the center image, is way to the front, as we know. With the bent lever, the movement is much more of an up and down vs. front to back. Last cross section is the 914-8 where the straight up shifter is pretty much in line (vertical) with the steering center point. The 914-8 had a completely different shifter linkage that actually went 90 degrees to the passenger side in front of the seat, then along the passenger long. @Montreal914 Got the 1/2 shafts back in so I could roll it out. Here are the pics you requested showing the shifter in relation to the steering wheel. Some pics have the straight edge , which was level vertically, against the wheel and some against the horn pad. |
Lo-Fi Version | Time is now: 23rd April 2024 - 12:37 AM |
