Valve adjuster squashed |
nditiz1 |
Jun 29 2020, 02:45 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So doing a valve adjustment i found #3 intake to be very loose. I started to adjust and then found this. Why/how did this happen?
Also, why are my leakdown tests consistently 20% leaking through the case? Rings? I did it cold and the engine looks to be rebuilt from how clean the inside of the heads were. |
nditiz1 |
Jun 29 2020, 05:36 PM
That stinks Bob.
So I put a good used one in its place. Torqued it back up and move o to cylinder 4. Im hoping what I found here was a rocker shaft nut and nothing more. The nuts on shaft 3 are copper, not the stock ones. I believe the PO said he had to fix a rocker on number 3 lets hope this is the only hardware that got left behind |
porschetub |
Jun 29 2020, 05:55 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
That stinks Bob. So I put a good used one in its place. Torqued it back up and move o to cylinder 4. Im hoping what I found here was a rocker shaft nut and nothing more. The nuts on shaft 3 are copper, not the stock ones. I believe the PO said he had to fix a rocker on number 3 lets hope this is the only hardware that got left behind Shit that's not good,looks like the pushrod retainer spring hasn't been fitted properly and has chewed up your pushrods. I would tear down rocker gear on both side and do a full R&R with everything done right. |
Lo-Fi Version | Time is now: 26th April 2024 - 03:29 AM |
