Valve adjuster squashed |
nditiz1 |
Jun 29 2020, 02:45 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So doing a valve adjustment i found #3 intake to be very loose. I started to adjust and then found this. Why/how did this happen?
Also, why are my leakdown tests consistently 20% leaking through the case? Rings? I did it cold and the engine looks to be rebuilt from how clean the inside of the heads were. |
nditiz1 |
Jun 29 2020, 05:36 PM
That stinks Bob.
So I put a good used one in its place. Torqued it back up and move o to cylinder 4. Im hoping what I found here was a rocker shaft nut and nothing more. The nuts on shaft 3 are copper, not the stock ones. I believe the PO said he had to fix a rocker on number 3 lets hope this is the only hardware that got left behind |
porschetub |
Jun 29 2020, 05:55 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
That stinks Bob. So I put a good used one in its place. Torqued it back up and move o to cylinder 4. Im hoping what I found here was a rocker shaft nut and nothing more. The nuts on shaft 3 are copper, not the stock ones. I believe the PO said he had to fix a rocker on number 3 lets hope this is the only hardware that got left behind Shit that's not good,looks like the pushrod retainer spring hasn't been fitted properly and has chewed up your pushrods. I would tear down rocker gear on both side and do a full R&R with everything done right. |
RoadGlue |
Jun 29 2020, 08:07 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Shit that's not good,looks like the pushrod retainer spring hasn't been fitted properly and has chewed up your pushrods. I would tear down rocker gear on both side and do a full R&R with everything done right. (IMG:style_emoticons/default/agree.gif) The pushrod wall material is pretty thick, but I'd always have a little voice in the back of my head questioning their integrity. It's just one of those parts that if it were to fail it would rain a lot of debris into the heart of your motor. |
porschetub |
Jun 30 2020, 01:17 AM
Shit that's not good,looks like the pushrod retainer spring hasn't been fitted properly and has chewed up your pushrods. I would tear down rocker gear on both side and do a full R&R with everything done right. (IMG:style_emoticons/default/agree.gif) The pushrod wall material is pretty thick, but I'd always have a little voice in the back of my head questioning their integrity. It's just one of those parts that if it were to fail it would rain a lot of debris into the heart of your motor. The fitment of the spring retainer has to be right,they frequently get bent out of shape when removed or put on wrong,this needs to be sorted. Yes these pushrods are heavy wall but not there to get chewed by the retainer spring. I see from the pic the heads they have had the heavy duty rocker studs fitted...that's a bonus,the ''copper nuts" mentioned aren't made of copper,just plated steel nuts. |
Lo-Fi Version | Time is now: 19th April 2024 - 10:14 PM |
