> ZF Diff, Price Check
EdwardBlume
post Jun 29 2020, 05:51 PM
I’m looking to sell off some extra parts.
What’s a ZF limited slip diff worth?
In a rebuilt 901 tranny with 3241 miles?
And a new intermediate plate at the time?
Thanks,
brant
post Jun 29 2020, 09:23 PM
Not sure but I wish I could afford it.
Bump
EdwardBlume
post Jun 29 2020, 11:32 PM
I guess they went into the 914/6 GT cars....
sixnotfour
post Jun 30 2020, 08:07 AM
some 914-4s had em , factory
post Jun 30 2020, 08:19 AM
914-6 GT in waiting
QUOTE(sixnotfour @ Jun 30 2020, 10:07 AM) *
One at our shop does. Came on a 1.8
Superhawk996
post Jun 30 2020, 04:15 PM
QUOTE(EdwardBlume @ Jun 29 2020, 07:51 PM) *
Thanks,
IMHO value is capped by cost for a new Torsen or Quaife Helical LSD. About $2k.
There may be some "extra" value to someone looking for a factory style multi plate clutch LSD but then you run into all sorts of questions about whether or not the clutch plates are still serviceable and how worn the LSD housing might be, how worn the springs are, and the parts that are either NLA or hard to find.
There was an OEM plate style LSD on F/S about a year ago that went to about $1600, it also came with the appropriate transmission stubs that are hens teeth.
http://www.914world.com/bbs2/index.php?sho...338115&st=0
YRMV.
EdwardBlume
post Jul 1 2020, 02:20 PM
Thanks for the input and good to know the details. I’ll see if I can find a good home that will use it!
sixnotfour
post Jul 1 2020, 02:57 PM
QUOTE(EdwardBlume @ Jul 1 2020, 02:20 PM) *
I assume it has 914 output flanges ??
horizontally-opposed
post Jul 1 2020, 06:20 PM
Curious if people have a preference once "factory-ishness" and cost are taken out of the equation.
Drove a car with a torque-biasing diff a few years ago and didn't like it. Might have been a matter of suspension setup, but the car had odd tendencies as you rolled into the throttle on the way out of tight turns. It made me wonder if I might prefer the Quaife or factory LSD.
Montreal914
post Jul 1 2020, 11:40 PM
Superhawk996
post Jul 2 2020, 06:12 AM
QUOTE(horizontally-opposed @ Jul 1 2020, 08:20 PM) *
All LSD's will induce understeer on corner exit. Nature of the beast.
It's a matter of degree depending on the the spec's of the LSD.
If you set up the LSD to not do much bias on wheel slip, you won't get as much understeer tendency. But . . . no free lunch . . . you loose the effectivenss of the LSD when you have lots of wheel slip.
The suspension can be set up (via springs, shocks, and bars) to have more tendency to oversteer to offset the LSD understeer. But of course that brings along a whole new set of problems. Oversteer is not desirable and it also become load dependent on a street car which is not as much of an issue on a race car.
Modern electronic LSD's solve this problem to a large degree by being able to tune how and when the LSD activates.
- Lo-Fi Version Time is now: 4th July 2025 - 05:02 AM
