Are My Piston Up-Side-Down |
SuperSquid |
Jun 29 2020, 06:54 PM
Newbie Group: Members Posts: 24 Joined: 26-February 20 From: Louisville Kentucky Member No.: 23,972 Region Association: South East States |
Carbon-14 |
Jul 1 2020, 12:28 AM
Senior Member Group: Members Posts: 765 Joined: 7-May 20 From: Toronto, Ontario, Canada Member No.: 24,238 Region Association: Canada |
Better be sure the rings are gapped to the correct dimension, yes, you did have them upside down. Check the cold clearances of the piston to cylinder wall, to make sure it won't seize when running. Measure piston's height to cylinder head clearance, important to avoid big bangs for bucks. Buy new rod bolts and torque to spec, you did measure clearance's of new bearings. Everthing is spotless clean, right ?
Easy to do things wrong, without instruction or experience. All the info is right here. https://sites.google.com/site/stpsgarage/Te...ndersforinstall https://jalopnik.com/heres-what-happened-in...kswa-1819961495 |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:21 AM |
