Speedodrive seal, should it drop in or should it be 'forced' ? |
Frankvw |
Jun 30 2020, 06:09 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
Hi, replacing the seals on the speedodrive. (combining it with the gearboxoil change)
(inspired by the saturday video of Ian / Cuddy_K) O-ring makes perfect sense. Easy one. But the seal.... I had a hard time getting the old seal out, so it came out in pieces in the end. The new seal does not just drop in position. Should the new shaft seal (999 113 036 50) just drop in ? Or do I just put the shaft in, seal around the end of the shaft and then the rest of the parts will press it further in when I am assembling it back ? Or do you press the seal in first and then the shaft through it ? Any tips ? Thanks ! |
Mikey914 |
Jul 1 2020, 08:16 AM
The rubber man Group: Members Posts: 12,657 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
They (the washer) are available from the dealer and I do not believe they do come with.
As far as order the bushing we make it comes with all 3 seals, just not the washer as they are rarely worn that bad. -Mark |
Lo-Fi Version | Time is now: 8th May 2024 - 05:39 PM |
