more side shifter linkage parts |
brant |
Jun 30 2020, 02:57 PM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I just learned this shifter is missing a spacer.
so I'm selling the 3 pieces of linkage for $25 now. buyer is welcomed to have the shifter, and indent plate if they want to have it. New Price is $25 plus actual shipping costs to the buyers address. brant Please note. The shifter is missing the 2 springs. I used to run a weltmeister aftermarket heavier spring in this shifter. I don't know where I used the welt, springs when this was pulled from the car. I also had replaced the detent shift plate when this was in my old race car. So it has very little wear on the detent plate. buyer would need to replace the 2 springs... stock/or heavy duty. The pins and hardware for the springs are intact. also included are: - a rear shift bar - the bushing cup at the rear of the linkage - and the front attachment at the base of the shifter - shifter minus 2x springs all of the length of the shift rod will add to the cost of shipping some but shipping is ACTUAL shipping to your destination Attached thumbnail(s) |
brant |
Jun 30 2020, 03:24 PM
Sounds good
Pm coming |
bdstone914 |
Jun 30 2020, 06:52 PM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
brant
' date='Jun 30 2020, 02:24 PM' post='2829632'] Sounds good Pm coming [/quote] That shifter looks like the one that has a hardened bushing that inserts into the hole at the bottom which attaches the right angle part that clamps on the shift rod. They get lost. The later side shift shifters had no bushing and an 8mm hole. |
brant |
Jul 1 2020, 07:10 AM
[quote name='bdstone914' date='Jun 30 2020, 06:52 PM' post='2829686']
brant ' date='Jun 30 2020, 02:24 PM' post='2829632'] Sounds good Pm coming [/quote] That shifter looks like the one that has a hardened bushing that inserts into the hole at the bottom which attaches the right angle part that clamps on the shift rod. They get lost. The later side shift shifters had no bushing and an 8mm hole. [/quote] Thank you Bruce you have saved me again I didn't realize this I'll measure the shifter hole. sounds like if it is large.. needing a spacer... then I'm missing that part. and will adjust my ad right now. brant |
Lo-Fi Version | Time is now: 8th May 2024 - 05:36 PM |
