| bkrantz |
Jun 30 2020, 05:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,812 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Dansk battery tray (new), $50. SOLD
RD engine lid hinge brackets, pair (new) $40 SOLD AA right rear inner wheelhouse panel, center section cut out (new) $50 SOLD Left front fender, front half (good used) $25 Right vertical front trunk support (very good used) $15 Center part of front panel (good used) $10 SOLD Rear jack point gussets and donuts, left and right (used) PENDING and 914 rear reflector panel (very good used except for chip on lower left corner) $15 SOLD all prices plus shipping from Colorado Attached thumbnail(s) |
| Literati914 |
Jun 30 2020, 05:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,398 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Wheelhouse piece i'll take
..and the jack point gussets / donuts please. |
| dlee6204 |
Jun 30 2020, 05:31 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
PM sent
| poorsche914 |
Jun 30 2020, 05:40 PM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,163 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I'll take this if not yet spoken for...
914 rear reflector panel (very good used except for chip on lower left corner) $15 PM on its way (IMG:style_emoticons/default/driving.gif) |
| 76-914 |
Jun 30 2020, 07:32 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,986 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA
| bkrantz |
Jul 1 2020, 01:54 PM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). |
| Literati914 |
Jul 1 2020, 08:51 PM
Wheelhouse piece i'll take ..and the jack point gussets / donuts please. PM sent Guess I'll have to go back to sending pm's before 'calling' a part, thanks for nothin' (IMG:style_emoticons/default/headbang.gif) |
| G e o r g e |
Jul 2 2020, 01:07 AM
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None
| 76-914 |
Jul 2 2020, 11:24 AM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) |
| 76-914 |
Jul 3 2020, 11:08 AM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent |
| bkrantz |
Jul 4 2020, 09:17 PM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent Kent, I will find a box and estimate shipping. |
| bkrantz |
Jul 5 2020, 05:12 PM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent Kent, looks like UPS ground to Temecula would be about $16. |
| 76-914 |
Jul 5 2020, 07:33 PM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent Kent, looks like UPS ground to Temecula would be about $16. Sounds good. PayPal? |
| bkrantz |
Jul 6 2020, 11:57 AM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent Kent, looks like UPS ground to Temecula would be about $16. Sounds good. PayPal? Sent you a PM. |
Lo-Fi Version | Time is now: 25th October 2026 - 10:52 AM |
