Body Parts FS and Free |
bkrantz |
Jun 30 2020, 05:10 PM
914 Guru Group: Members Posts: 7,746 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Dansk battery tray (new), $50. SOLD
RD engine lid hinge brackets, pair (new) $40 SOLD AA right rear inner wheelhouse panel, center section cut out (new) $50 SOLD Left front fender, front half (good used) $25 Right vertical front trunk support (very good used) $15 Center part of front panel (good used) $10 SOLD Rear jack point gussets and donuts, left and right (used) PENDING and 914 rear reflector panel (very good used except for chip on lower left corner) $15 SOLD all prices plus shipping from Colorado Attached thumbnail(s) |
76-914 |
Jun 30 2020, 07:32 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA
bkrantz |
Jul 1 2020, 01:54 PM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). |
76-914 |
Jul 2 2020, 11:24 AM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) |
76-914 |
Jul 3 2020, 11:08 AM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent |
bkrantz |
Jul 4 2020, 09:17 PM
What is the width of Center part of front panel. I need to patch a gigantic cut. It looks wide enough but I'd like to be sure before ordering it. TIA 29 inches wide, and close to centered. The height is the full panel, from the lower seam with the floor to the upper weather strip channel (which is a bit rusty toward the left side). I'll measure mine today and get back with you tonight. Thx (IMG:style_emoticons/default/beerchug.gif) That will work as long as the shipping cost isn't more than $20. My opening is 26".Thx, Kent Kent, I will find a box and estimate shipping. |
Lo-Fi Version | Time is now: 4th May 2024 - 06:36 AM |
