Thinking out loud - 1911, Found my deck height. All good? |
jaredmcginness |
Jul 4 2020, 10:03 AM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
See update and actual numbers on the added reply.
Sorry for the novel!! Hey guys, I'm building a 1911. I want to make sure that I have my thoughts in the right place. -96 Bore x 66 stroke. Fresh rebuilt 1.7 heads with a 105mm fly cut register. Stock valves -Running a .495 lift cam, lifters to match, HD springs + counter bore .630 (IIRC) extended. I need to CC my heads first, get the volume, then determine my deck height and compression ratio? Stock 1.7 heads are 50cc. I assume mine will end up a tad larger, maybe 52cc. (will the fly cut alter the size?) But I might be off. Is 8.5:1 a good target ratio? Ive read a few threads and this seems to be the middle ground compression. A good target DH is .045-.065? With a minimum of 0.040 to avoid contact. A few examples - per a CR calculator: 50cc, 0.065 = 8.7:1 50cc, 0.045 = 9.2:1 53cc, 0.065 = 8.4:1 53cc, 0.045 = 8.8:1 This in mind, depending on my head volume it should be easy to narrow down where I need to be. Am I on the right track? New to this and been digging into some old books. Whats a good compression ratio, that should be safe for a mild carbed (dual 36) motor and mild cam. Want this thing to last more than a summer! I dont really have a target CR, because I dont know the difference of a few decimal points! Happy 4th (IMG:style_emoticons/default/beerchug.gif) ! |
iankarr |
Aug 1 2020, 07:30 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
What brand of P&C are you using? The reason I ask is that, in my 2056 build which I'm in the middle of now, the AA pistons I bought gave me a deck height over 70 with no shims. I spoke with @mark henry who recommended KB pistons and cylinders instead, and the deck came in at .040. Much better. What's weird is that I took a caliper to the jugs and the KB and AA measured exactly the same from the sealing base to the top. There must be something about the way the AA pistons are cast that makes the top closer to the wrist pin.
jaredmcginness |
Aug 1 2020, 08:58 PM
What brand of P&C are you using? The reason I ask is that, in my 2056 build which I'm in the middle of now, the AA pistons I bought gave me a deck height over 70 with no shims. I spoke with @mark henry who recommended KB pistons and cylinders instead, and the deck came in at .040. Much better. What's weird is that I took a caliper to the jugs and the KB and AA measured exactly the same from the sealing base to the top. There must be something about the way the AA pistons are cast that makes the top closer to the wrist pin. Using AA. (Unfortunately). How’d you guess (IMG:style_emoticons/default/dry.gif) Funny you say that, I was looking at the KB pistons FAT uses and was considering advantages of swapping them in (same cylinders) That explains the over .070 with no shims. |
Lo-Fi Version | Time is now: 25th April 2024 - 11:03 AM |
