Stripped exhaust stud on fresh rebuilt heads, Fireworks at my place tonight |
djway |
Jul 5 2020, 01:40 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Soooooo
I am installing the exhaust manifolds today, using the nice little copper coated exhaust nuts from Bel Metric and at the point the self locking threads encounter the stud, the stud just starts turning. Little effort to pull it out and the stud is clean, no material in the threads. Now mind you that these heads have just been rebuilt and fixing exhaust studs was on the to do list and the cost was substantial to me. Then the fireworks went off... (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/hissyfit.gif) As the great poet Eric Burdon said in the song PC3 "I rattled so long And rattled so obscene The ground did shake And disturbed the Queen..." This is the motor in my Notchback and it has taken too long to squeeze that puppy in there so this fix is going to be in site. Is it an optical illusion or are the studs at an angle? ie not perpendicular to the ground? I ordered some EZLOCK solid inserts and I will make a drill guide that will bolt onto the other stud. Apologies to the neighbors (IMG:style_emoticons/default/blink.gif) |
djway |
Jul 7 2020, 10:27 PM
Thanks to Bruce Stone for the exhaust manifold end piece.
At first I drilled it out and used it to guide the drill when drilling into the head. I then drilled it out further and used it to guide the tap. Here is a picture of the insert in place so you can see how big it is relative to the surrounding area. This is on the case side of the head. So far I have only tightened it with one hand fairly tight but all feel snug so far. |
Lo-Fi Version | Time is now: 27th May 2024 - 07:25 AM |
