Heat shed, what am I missing to cool her down?, *Update - 1st Test Run after cleanup - still HOT |
nditiz1 |
Jul 5 2020, 09:41 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Update - pass side tin removed. Signs of leakage.
*Update* - Webers were successful in scooting the teener down the road, but head temps still reached 400, engine drop to follow shortly. Stock 2.0 Engine Converted to carbs - (Dual 40 Dells - 60 Idle jet) Engine tin in place - needs seal on the passenger side Thermostat - dead/expanded - flaps auto spring to full open Valves set .006/.008 Timing 28 - New Pertronix SVDA - vac plugged when timed to 28 No AFR setup - want to say rich not lean New plugs NGK B6ES gapped to .028 *Updated info based on comments* Oil pressure when hot 40 PSI at 4k - so looks ok Oil currently in the block unknown - dark lol, but within the min and max marks Targa was on during test run Deflection flaps present Cooling fan has 1 broken fin CHT gauge is Dakota Digital under cyl#3 spark plug Engine lid is currently off - Dealer installed AC - Box and grate still in place - is this robbing the cool air from under the car at speed? Running oil temp 240/250F 85F ambient temp Head temps in 4th on flat cruising at 65 mph at 4k RPM - *400 and climbing if going up a hill Head temps in 3rd up and down hills *395, but can hit 400 if I get on it just a little Compression test was Cyl #1 - 135 Cyl #2 - 135 Cyl #3 - 130 - CHT temp sensor Cyl #4 - 135 Assuming the carbs are not lean (went 3 turns out, and now went to 4) what should I check next? I thought maybe I needed a rebuild since the compression numbers cold were around 125 with with a 12 psi gap between 2 of the cylinders, but this warm compression check looks healthy. The plugs do look a little white, but the last run I did was in the garage with it running at idle and some briefs to 3500 RPM to ensure the timing was correct. I know this is not to preferred method to check plugs as they should be done driving regularly and then shut off the engine and not let it idle to get a true reading. I have a gas tester I can maybe hook up to check the CO2 at the tail pipe (yes, I should have an AFR to get better readings) In the garage I was running at 350 head temp just at idle ambient temps 82. I know sitting has no air flow. I feel like when I rebuilt my last 2056, I could idle in the garage all day long at 300 or under. Let's assume the carbs are rich enough in the mixture so as to not be lean, will the engine seals being tattered and 1 missing (most crucial side (IMG:style_emoticons/default/dry.gif) ) be enough to make even back road driving push cyl 3 head temps to 400 and above? Plugs - less than 50 miles - maybe not enough time Cyl 1 and 2 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1593964487.1.jpg) Cyl 3 and 4 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-18763-1593964488.2.jpg) |
rhodyguy |
Jul 6 2020, 08:53 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I was unsure whether you were running Dels or Webers.
Lo-Fi Version | Time is now: 18th May 2024 - 10:49 AM |
