Metal Washers used on MC, can someone post a pic and/or dimensions of one? |
76-914 |
Jul 6 2020, 12:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I think I have an easy solution for installing the hose in the OEM style MC but need to test using the metal washers in place. TIA, Kent
sixnotfour |
Jul 6 2020, 03:38 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
901-355-936-00 8mm x 10mm ss Washer, for inlet lines for Master Cylinder. Fits 356C, 911, 912 914. 90135593600
sorry no thickness |
76-914 |
Jul 6 2020, 04:10 PM
901-355-936-00 8mm x 10mm ss Washer, for inlet lines for Master Cylinder. Fits 356C, 911, 912 914. 90135593600 sorry no thickness thx, I appreciate that.. just a test run. I'll make them 1mm. (IMG:style_emoticons/default/beerchug.gif) |
bdstone914 |
Jul 6 2020, 05:46 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@76-914
@sixnotfour post='2831524' date='Jul 6 2020, 02:38 PM'] 901-355-936-00 8mm x 10mm ss Washer, for inlet lines for Master Cylinder. Fits 356C, 911, 912 914. 90135593600 sorry no thickness [/quote] thx, I appreciate that.. just a test run. I'll make them 1mm. (IMG:style_emoticons/default/beerchug.gif) [/quote] That is wrong. O D is 13 mm, thickness 1 mm. I just measured a master cylinder. I think rhe hole is 10mm it has to clear the feed hole in the bottom of the bore. Attached thumbnail(s) |
UROpartsman |
Jul 6 2020, 06:03 PM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
The washers under the rubber grommets for the feed lines? 14mm OD x 8mm ID x 1mm thick
See this post for photos: http://www.914world.com/bbs2/index.php?s=&...t&p=2808079 |
76-914 |
Jul 6 2020, 07:57 PM
Well, looks like I need to make 3 sizes! (IMG:style_emoticons/default/lol-2.gif) JK. Apparently the metal washers purpose is to support the base of rubber washer while preventing the tube from passing thru and bottoming out? Or should the tube pass freely thru the metal washer? If so how would you know if it had bottomed out or not? (IMG:style_emoticons/default/idea.gif) So the OD of the metal washer should be just large enough to drop inside the MC and the ID should be equal to the OD of the tube or slightly larger? And the 1mm depth should leave the the lip of the rubber washer snug against the MC. Sound about right.
Edit:I just looked at the new MC and noticed that it is stepped. Probably why there are differing dimensions given. At the lowest point or bottom it measures 13.11mm; next step up measures 13.5mm and the top of bore measures 14.85mm. Does the washer sit upon the 1st step preventing the hose from bottoming out? I'll add a pic. |
bdstone914 |
Jul 6 2020, 08:22 PM
@76-914
date='Jul 6 2020, 06:57 PM' post='2831601'] Why are you trying to make them when they are available? Nothing wrong with the way Ate made them. |
76-914 |
Jul 6 2020, 10:10 PM
@76-914 date='Jul 6 2020, 06:57 PM' post='2831601'] Why are you trying to make them when they are available? Nothing wrong with the way Ate made them. @bdstone914 Bruce, I want to prove to myself this easy install will work. Remember my genius idea for installing those trailing arm bushings. (IMG:style_emoticons/default/lol-2.gif) Well this works but I want to place a washer in there to be 100% surebefore I embarrass myself, again. I will install the MC on my 76 one day but not now. Therefor I don't have any washers at present. I'll share this info with everyone shortly. (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Jul 7 2020, 02:07 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'll give you a set to see if there's an easy way to install the rubber bits on top. So far the washers don't actually "help".
I've been giving them away with the new master cylinders lately. |
UROpartsman |
Jul 7 2020, 09:30 AM
The washer should rest on the step, see Boomguy's post: http://www.914world.com/bbs2/index.php?s=&...t&p=2808079
Ok I now understand where the washer needs to go, bear with me here. I removed a 19mm M/C out of my car today because ... well it looked like ithad been used as an anchor, previous owner put it in. I have on order a new MC but wasn't sure if it would come with washers so I checked the old one .... none, plus one of the two interior seals was backwards so I know why it looked the way it did. Now I asked my original question because I thought maybe I could find some, somewhere. The 19mm step measured at 14.35mm, in one of my drawers I actually found two washers that fit perfectly (14.25mm). Now when you guys said 8x10mm I thought I had the wrong area for the washer. I dug around and found the original 17mm MC and it did have washers... 13.95mm and confirmed that step in the pic. Now I realize the 17mm is oem and the19mm is aftermarket but there is only one part number from porsche. Sorry for rambling... |
76-914 |
Jul 9 2020, 07:39 PM
I can insert the plastic line, that was provided by Mark, by hand quite easily so I assume the complaints have been about trying to insert the plastic lines into the replacement MC once the MC is installed on the car. Is that correct? (IMG:style_emoticons/default/confused24.gif)
sixnotfour |
Jul 9 2020, 10:55 PM
QUOTE OEM style MC assumed you meant metal elbows into factory style...based on your first post.. |
Lo-Fi Version | Time is now: 4th May 2024 - 12:11 AM |
