WTB Charcoal canister and strap, Need canister and strap |
Medtner3 |
Jul 10 2020, 06:41 AM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
Need this item in rust free condition
TheCabinetmaker |
Jul 10 2020, 06:43 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Might want to included your model year.
Al Meredith |
Jul 10 2020, 01:05 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Plastic or steel ?
bdstone914 |
Jul 10 2020, 01:48 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Medtner3
To do have a gas tank that mounts the canister to it? They change in 74. 74 has unique strap that mounts the canister on a stud in the back of the engine bay. In 75 they moved it again and it has a different strap |
RenoRoger |
Jul 11 2020, 12:10 PM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
I do have one. Rust free with strap. it came out of a '72 or '73 and was mounted in the front trunk. $15 plus shipping.
Medtner3 |
Jul 12 2020, 06:22 PM
@Medtner3 To do have a gas tank that mounts the canister to it? They change in 74. 74 has unique strap that mounts the canister on a stud in the back of the engine bay. In 75 they moved it again and it has a different strap My car is a 74 2.0l not sure about the mounting I have replaced gas tank, I could probably figure out how to mount either front or engine bay I did not know that there were plastic ones I would need a steel one for 74-76 would work |
scallyk9 |
Jul 12 2020, 08:15 PM
Member Group: Members Posts: 320 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
@Medtner3 To do have a gas tank that mounts the canister to it? They change in 74. 74 has unique strap that mounts the canister on a stud in the back of the engine bay. In 75 they moved it again and it has a different strap My car is a 74 2.0l not sure about the mounting I have replaced gas tank, I could probably figure out how to mount either front or engine bay I did not know that there were plastic ones I would need a steel one for 74-76 would work I also have a 74 2.0l. Look for an indented flat surface and the stud at the front of the inside of the trunk, about six inches left of the right side hinge. If you have it, use it as it is a very tidy mounting point. The front trunk bulkhead is actually different on the 1974 models. |
Medtner3 |
Jul 13 2020, 05:41 PM
I do have one. Rust free with strap. it came out of a '72 or '73 and was mounted in the front trunk. $15 plus shipping. Do you have picture? If I’m not mistaken the 914s didn’t have a charcoal canister until 74 which was front trunk mounted and the 75-76 was engine bay mounted Do you have a picture? |
bdstone914 |
Jul 14 2020, 09:44 AM
@Medtner3
date='Jul 10 2020, 05:41 AM' post='2832562'] Need this item in rust free condition [/quote] I have this one for mounting on the tank. It only works if you tank has the brackets on the right side of the tank. In late 74 the canister was moved to the back of the engine bay and uses a different bracket. Attached thumbnail(s) |
Medtner3 |
Jul 14 2020, 03:59 PM
[quote name='bdstone914' date='Jul 14 2020, 10:44 AM' post='2833702']
@Medtner3 date='Jul 10 2020, 05:41 AM' post='2832562'] Need this item in rust free condition [/quote] I have this one for mounting on the tank. It only works if you tank has the brackets on the right side of the tank. In late 74 the canister was moved to the back of the engine bay and uses a different bracket. [/quote] My fuel tank does not have the bracket for mounting my 914 came out about July 1974 I have replaced the tank last year though I would need the engine bay bracket |
Medtner3 |
Jul 14 2020, 04:01 PM
Medtner3 |
Jul 15 2020, 08:00 PM
Lo-Fi Version | Time is now: 6th May 2024 - 05:52 PM |
