Frunk tire cover not sitting right? |
John90290 |
Jul 22 2020, 05:05 PM
Member Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None |
I have on oem size spare on a 15' stock rim and the tire seems to sit high and there for the front of the cover wont sit flat? is the spare a smaller size than the 165
/80 15? Seems the front is up on a ledge Attached image(s) |
Jonathan Livesay |
Jul 22 2020, 05:11 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
John90290 |
Jul 22 2020, 05:24 PM
I have on oem size spare on a 15' stock rim and the tire seems to sit high and there for the front of the cover wont sit flat? is the spare a smaller size than the 165 /80 15? Is the floor pushed up from an impact in the tow hook area? Looks good. Some small dents. Compared to online phots and looks same. Attached thumbnail(s) |
flipb |
Jul 23 2020, 11:00 AM
Senior Member Group: Members Posts: 1,722 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Mine has been this way as long as I've owned it. 4-lug Mahle wheels (including the spare).
(IMG:style_emoticons/default/popcorn[1].gif) |
Tbrown4x4 |
Jul 23 2020, 11:16 AM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Mine is the same. Drives me crazy, but I think that's how it is. I have steelies.
VoPo914 |
Jul 23 2020, 11:45 AM
Member Group: Members Posts: 74 Joined: 11-January 07 From: Lincoln, Nebraska Member No.: 7,449 Region Association: Northstar Region |
Mine is the same, just the way they are.
bbrock |
Jul 23 2020, 12:47 PM
Yep, me too. My trunk floor is perfect. I mounted a 195 tire on my Fuchs 4-spoke spare and it was really horrible. Swapped that for a 165 and the cover board still rides high - acceptable, but annoying. Might have to try a 155 and see how that works.
rgalla9146 |
Jul 24 2020, 05:11 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
It does look like a floor jack was used under the middle of the floor.
It probably doesn't cause your problem but can easily be fixed. Stand in the center of the floor with feet together. You'll probably feel it drop a bit. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:27 AM |
