original clutch, factory installed clutch parts |
wonkipop |
Jul 24 2020, 05:35 PM
Advanced Member Group: Members Posts: 4,299 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
1974 1.8
clutch started slipping after recommissioning. found interesting things dropping gearbox. (assembly sticker on case posted elsewhere). clutch was original type rubber centre disc plate - think thats what they were called. (with bits of it inside bell housing!). not sure why porsche used these, but understand they persisted on 911s well into the 80s. fatter than usual conventional spring type clutch plates. because of thickness central section of original clutch disc had just started to contact the flywheel bolts leading to slip. lasted 46 years and 44,000 miles. guessing last 16 years sitting wasn't great for it, particularly the rubber parts leading to demise - wonder it lasted this long. flywheel washer is cute, stamped vw type 4 part number and vw logo. don't get them like that anymore. |
wonkipop |
Sep 28 2020, 05:47 AM
now you have.
its the original item. no poor shifting while it was in the car. worked very well when i was driving it 16 years ago. just began slipping upon recommissioning. rubber core had finished the job of perishing during storage coupled with clutch plate wear at limit before storage. my comment would be that as a unit it worked very well for 25-30 years and 40,000 miles. as you can see from images the clutch plate had worn right to its limits and maybe a little beyond. but there were no shifting issues. just slipping. amazed it still worked at all when we pulled it out. going ok now with replacement spring type clutch plate. also renewed one worn bush in shifter linkage at rear where shifter rod connects to gear box. took two months to get hold of the bush from a supplier in the usa. gear shift now very precise, like showroom. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:34 PM |
