No turnsignals and hazards, a blew a fuse huh! |
Aaron Cox |
Jul 19 2003, 06:10 PM
yes or no?
tryan |
Jul 20 2003, 12:18 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
good luck. the hazard switch has a relay that ties the left and right markers together. i would suspect the power comming into the stalk switch if you cannot find an obvious problem like a loose wire at the fuse box.
you will go blind if you stare at the diagram to long. print it and take a highlighter to it. yellow is faster. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:23 PM |
