nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 546 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Edit******* Bought one from QSC for $223 shipped.
So i realized my 2.7 engine is missing a flywheel. In order to mate it up properly to the 901 id need a 914-6 flywheel or one from an early 911. Looks like the cheapest OE I found was $385. AA has a rebuilt one for $200 with a $100 core. @dr914 - how does one rebuild a metal flywheel? Also what kind of core is needed? Can I trade in my 914 flywheel? Edit* - Not sure how I missed this before, but it does say rebuilt/reproduction. Most likely that term is used interchangeably. For this application it is probably solely repro |
stownsen914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None ![]() |
I'd imagine a rebuilt flywheel has just been resurfaced and checked.
Unless I'm mistaken, a 911 flywheel through '69 should be interchangeable with a 914/6 one. |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,465 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Yes, interchangeable but importantly a 911 part does not have timing marks
or valve adjustment marks that a 914 6 has. You'll have no way to set timing or position crank to adjust valves If you use a 911 be sure to mark it before installing. Or poke a big hole in your seat bulkhead. ' Rebuilt' ? ....hyperbole. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,269 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Yes, interchangeable but importantly a 911 part does not have timing marks or valve adjustment marks that a 914 6 has. You'll have no way to set timing or position crank to adjust valves If you use a 911 be sure to mark it before installing. Or poke a big hole in your seat bulkhead. ' Rebuilt' ? ....hyperbole. I got caught up on this years ago. I sold a brand new '6 flywheel to a nationally respected, PCA tech advisor's shop in TX years ago. I got a call that he said "this flywheel is bad, it's marked wrong". After paying to get a new flywheel and eating shipping, I found out that engine had a 2.4 crank, which indexes differently than a 914-6, it's a bolt up part but the timing marks are off. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,156 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Did you look on AA Piston's web site?
nditiz1 |
I did. I don't think they carry a 215mm 6 bolt flywheel anymore
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,115 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
nditiz1 |
porschetub |
I did. I don't think they carry a 215mm 6 bolt flywheel anymore QSC have one listed for $208,cheers. Nice find! Bought! I won't be as the genuine 914/6 flywheel which is drilled for weight removal and most likely won't have a TDC mark ,the timing mark can easily be marked with a sharp chisel. Hope you have the 6 mounting bolts as they are crazy money,I found a NOS set on ebay and saved a heap so shop around for these as the prices are all over the place. |
Lo-Fi Version | Time is now: 20th January 2021 - 10:35 AM |
