AA's Rebuilt 914-6/911 flywheel |
nditiz1 |
Jul 31 2020, 07:07 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Edit******* Bought one from QSC for $223 shipped.
So i realized my 2.7 engine is missing a flywheel. In order to mate it up properly to the 901 id need a 914-6 flywheel or one from an early 911. Looks like the cheapest OE I found was $385. AA has a rebuilt one for $200 with a $100 core. @dr914 - how does one rebuild a metal flywheel? Also what kind of core is needed? Can I trade in my 914 flywheel? Edit* - Not sure how I missed this before, but it does say rebuilt/reproduction. Most likely that term is used interchangeably. For this application it is probably solely repro |
rgalla9146 |
Aug 1 2020, 05:33 AM
Advanced Member Group: Members Posts: 4,544 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Yes, interchangeable but importantly a 911 part does not have timing marks
or valve adjustment marks that a 914 6 has. You'll have no way to set timing or position crank to adjust valves If you use a 911 be sure to mark it before installing. Or poke a big hole in your seat bulkhead. ' Rebuilt' ? ....hyperbole. |
Lo-Fi Version | Time is now: 20th April 2024 - 05:39 AM |
