Wiring Harness Restoration |
bkrantz |
Jul 31 2020, 08:41 PM
914 Guru Group: Members Posts: 7,753 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I have a bunch of questions about restoring the main and engine harnesses.
Any material or process to restore flexibility in the wire insulation? Same for the original outer tubing? For breaks in wires and large holes in the insulation, I think the best solution (short of running a complete new wire) is to solder-splice the break, and cover it with heat-shrink tubing--yes? Any good way to seal small holes and cracks in insultation? When replacing missing or broken spade connectors, crimp only or crimp and solder? |
914Sixer |
Aug 1 2020, 12:41 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bite the bullet, buy new reproduction and move on if you want your engine to run right. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 7th May 2024 - 04:56 PM |
