How much torque is too much?, Removing fan yoke |
ctc911ctc |
Aug 1 2020, 02:08 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear) I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,, I am using penetrating oil on the shaft,,,,,,,,,what next? Heat? Incantations? Ideas? (IMG:style_emoticons/default/confused24.gif) |
sixnotfour |
Aug 2 2020, 09:35 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Is the puller going through the bore of the flange ?? Looks to big in diameter to go through....put the bolt in it and back off a couple turns , and push on the head , with puller..
ctc911ctc |
Aug 2 2020, 11:12 AM
I have 6 pullers of various size, this puller has the bolt part that fits perfectly within the shaft (without touching the threads) and has the arms off of the smallest puller so they fit on the ears of the yoke.
Thank you! Is the puller going through the bore of the flange ?? Looks to big in diameter to go through....put the bolt in it and back off a couple turns , and push on the head , with puller.. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:57 PM |
