How much torque is too much?, Removing fan yoke |
ctc911ctc |
Aug 1 2020, 02:08 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear) I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,, I am using penetrating oil on the shaft,,,,,,,,,what next? Heat? Incantations? Ideas? (IMG:style_emoticons/default/confused24.gif) |
pilothyer |
Aug 1 2020, 03:32 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If you heat it up with a MAPP torch with it under that much pressure it will probably jump right off.
ctc911ctc |
Aug 1 2020, 03:46 PM
mepstein |
Aug 1 2020, 04:19 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Ahhhhh I only have a propane torch,,,,,, will keep trying If you heat it up with a MAPP torch with it under that much pressure it will probably jump right off. It's really worth buying MAP. Less than $50 at the big box stores and you will find many uses for it. |
Lo-Fi Version | Time is now: 28th April 2024 - 04:52 PM |
