How much torque is too much?, Removing fan yoke |
ctc911ctc |
Aug 1 2020, 02:08 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear) I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,, I am using penetrating oil on the shaft,,,,,,,,,what next? Heat? Incantations? Ideas? (IMG:style_emoticons/default/confused24.gif) |
pilothyer |
Aug 1 2020, 03:32 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If you heat it up with a MAPP torch with it under that much pressure it will probably jump right off.
ctc911ctc |
Aug 1 2020, 03:46 PM
Superhawk996 |
Aug 1 2020, 04:41 PM
914 Guru Group: Members Posts: 5,760 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Ahhhhh I only have a propane torch,,,,,, will keep trying If you heat it up with a MAPP torch with it under that much pressure it will probably jump right off. Part of the trick with MAPP or OxyAcetylene is that you can get lots of heat in the hub quicker than it can tranfer into the crankshaft. That expands the hub faster than the crank and loosens the taper fit. Heating too slowly allows both parts to heat up at near the same rate and doesn't loosen the fit. Way back when I really 1st getting into my 914 I bought a MAPP & Oxygen setup at K-Mart. Yup - Dinosaurs roamed the aisles. It was worth it's weight in gold for so many jobs. It was expensive to operate (Oxygen cylinders weren't cheap). But so worth it when I couldn't have even comprehended the cost of owning an oxy acetylene rig. Was like this: https://www.tractorsupply.com/tsc/product/b...azing-torch-kit At a bare minimum run MAPP gas though your propane torch that alone is a decent upgrade in heat. |
Lo-Fi Version | Time is now: 28th April 2024 - 09:46 PM |
