How much torque is too much?, Removing fan yoke |
ctc911ctc |
Aug 1 2020, 02:08 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
‘74 2.0 22k
While I wait for the dog teeth to be delivered, I thought I would change the seals (front and rear) I built a tool for my wheel puller - have turned it to about 80 ft/lbs, kinda worried to crank it another turn,,,,,, I am using penetrating oil on the shaft,,,,,,,,,what next? Heat? Incantations? Ideas? (IMG:style_emoticons/default/confused24.gif) |
Jake Raby |
Aug 1 2020, 06:22 PM
These can be tough. They are also getting rare to find in perfect condition, so trying not to damage the hub (or bend the ears) is a goal as well.
I have had good luck with placing a decent load on the 3 arm puller, and then using an air hammer to shock the hub. Heat with the MAPP gas can be added to this mix if necessary as well. |
ctc911ctc |
Aug 1 2020, 06:53 PM
Is this the right setup for high and fast heat?
https://www.acehardware.com/departments/too...979?store=08546 These can be tough. They are also getting rare to find in perfect condition, so trying not to damage the hub (or bend the ears) is a goal as well. I have had good luck with placing a decent load on the 3 arm puller, and then using an air hammer to shock the hub. Heat with the MAPP gas can be added to this mix if necessary as well. |
Lo-Fi Version | Time is now: 28th April 2024 - 08:51 PM |
