914-6 Conversion throttle/cooler/shifter shaft |
nditiz1 |
Aug 1 2020, 07:09 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Looking for recommendations on the following:
*Note I am unable to buy from Rich Thanks all! |
Retroracer |
Aug 1 2020, 08:44 PM
Senior Member Group: Members Posts: 608 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
For the oil cooler mod I used Clewett Engineering:
https://www.clewett.com Shipped the cooler to him, got it back modified and pressure tested for a reasonable price. He done a few of them and offers AN or metric welded fittings. If I recall, you cannot use a 90deg metric to AN adapter as it fouls the suspension mount? Just not enough room, hence the well-known mod. - Tony |
mepstein |
Aug 1 2020, 08:51 PM
914-6 GT in waiting Group: Members Posts: 19,222 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Ben can weld the oil cooler fitting.
porschetub |
Aug 1 2020, 09:19 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
porschetub |
Aug 1 2020, 09:38 PM
Looking for recommendations on the following: Throttle linkage(Rich's type setup) Oil cooler 90 mod *Note I am unable to buy from Rich Throttle linkage ?? if you are carefully you can drill the g/box and fit a 911 pivot stud and bellcrank assembly,some mods involved but mine works for $100 outlay including curved rod to carbs. Mines ''ass about face'' but works fine. |
IronHillRestorations |
Aug 2 2020, 06:47 AM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
What year is your car? Most tail shifters have the boss for the throttle pivot rod. If you are getting your trans rebuilt, see if they can use an early intermediate plate, and you'd be good to go
mb911 |
Aug 2 2020, 03:05 PM
914 Guru Group: Members Posts: 6,801 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I think Sir Andy used the PMS single cable solution. I swear its about $100
mb911 |
Aug 2 2020, 03:06 PM
Oh and I have a fixture to mod your shift linkage.
Optimusglen |
Aug 3 2020, 07:48 AM
Senior Member Group: Members Posts: 901 Joined: 26-February 16 From: Minneapolis Member No.: 19,709 Region Association: Upper MidWest |
I think Sir Andy used the PMS single cable solution. I swear its about $100 I just purchased this one for my swap too. Seemed like a simple and cheap alternative to the bell crank linkage. It's $140 http://patrickmotorsports.com/products/eng...2dd02&_ss=r |
nditiz1 |
Aug 3 2020, 08:56 AM
I think Sir Andy used the PMS single cable solution. I swear its about $100 I just purchased this one for my swap too. Seemed like a simple and cheap alternative to the bell crank linkage. It's $140 http://patrickmotorsports.com/products/eng...2dd02&_ss=r I did as well (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 02:40 PM |
