Turn signal switch |
partwerks |
Aug 4 2020, 09:23 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
On the turn signal switch, if one side is not cancelling out. Is something inside that's causing it, fixable?
dangrouche |
Aug 5 2020, 08:11 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
Check the steering wheel canceling ring as well. It’s on the back of the hub. I’ve had a turn signal switch that appeared intact but did not cancel. It can be tested when the steering wheel is removed. Turn signal left or right and at the three o’clock position force the tab with a small flat blade screwdriver Up Or down
Lo-Fi Version | Time is now: 14th May 2024 - 07:25 AM |
