Axle bolts and Pins, I done messed up |
tvdinnerbythepool |
Aug 7 2020, 07:56 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Axle fell of the transmission yesterday. Bent a bolt and sheared a bolt. The other two appear to be fine and just loosened themselves out.
My assumption is I didn't torque them down correctly. Question is..... Bolt size? I have M8 special bit And... There are 6 holes....4 bolts and 2 alignment pins correct? I appear to have lost those 2 pins when the axle came off. Source for the 2 pins? Thanks all! -R |
rhodyguy |
Aug 7 2020, 02:10 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Not so sure the outer hub recesses are supposed to be packed with grease. McMaster/Carr is the place to buy the Schnor washers. Also known as 'Belleville'. Spelling might be off. Buy a 100 pack. They work well for the intakes on carbed cars rather than cut washers
Lo-Fi Version | Time is now: 15th May 2024 - 01:51 PM |
