Axle bolts and Pins, I done messed up |
tvdinnerbythepool |
Aug 7 2020, 07:56 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Axle fell of the transmission yesterday. Bent a bolt and sheared a bolt. The other two appear to be fine and just loosened themselves out.
My assumption is I didn't torque them down correctly. Question is..... Bolt size? I have M8 special bit And... There are 6 holes....4 bolts and 2 alignment pins correct? I appear to have lost those 2 pins when the axle came off. Source for the 2 pins? Thanks all! -R |
ClayPerrine |
Aug 7 2020, 06:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
100% agree with using the torque wrench. At one time I was poor, and didn't replace the schnorr washers plus I didn't use a torque wrench. Ended up losing the CV joint and bending the shift rod.
ALWAYS replace the schnorr washers and CV gaskets. Use the proper tool and a torque wrench to torque the bolts to 31 lb/ft. And every time you get under the car, visually check all 8 bolts. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:33 PM |
