Axle bolts and Pins, I done messed up |
tvdinnerbythepool |
Aug 7 2020, 07:56 AM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Axle fell of the transmission yesterday. Bent a bolt and sheared a bolt. The other two appear to be fine and just loosened themselves out.
My assumption is I didn't torque them down correctly. Question is..... Bolt size? I have M8 special bit And... There are 6 holes....4 bolts and 2 alignment pins correct? I appear to have lost those 2 pins when the axle came off. Source for the 2 pins? Thanks all! -R |
rhodyguy |
Aug 7 2020, 02:10 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Not so sure the outer hub recesses are supposed to be packed with grease. McMaster/Carr is the place to buy the Schnor washers. Also known as 'Belleville'. Spelling might be off. Buy a 100 pack. They work well for the intakes on carbed cars rather than cut washers
Superhawk996 |
Aug 8 2020, 09:18 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Also known as 'Belleville'. Spelling might be off. Buy a 100 pack. They work well for the intakes on carbed cars rather than cut washers Long side note: Schnorr washers are a type of Belleville washer (disc spring washer - or conical spring washer). However, Generic Belleville (plain or serrated) washers are not Schnorr washers. Schnorr washers have a slightly different trapezoidal gear tooth pattern pressed into them that has a lower coefficient of friction when tighetening and a higer coefficient of friction in the loosening direction once the disc spring is under pre-load when the fastener is tightened. Schnorr also has specific washer type "VS" for use with grade 12.9 fasteners like the tri-square 12 point CV Joint fasteners. Honestly I don't know for sure if VW/Porsche originally used the VS grade Schnorr washers. I would suspect that they were sourced and specified to work with the OEM fastners even if they weren't referred to as VS seiries back then. https://www.schnorr-group.com/en/products/safety-washers/ I'm sure a generic Bellville washer is beter than a 50 year old Schnorr that is worn out from multiple reuses. In the end the fastener isn't retained by any sort of washer. A fastener is retained in place by clamp load that results from being tightened properly and developing a strech in the fastner that works like a very high rate spring. When used in OEM method - single washer under the bolt head. The spring rate of the fastener shank is far higher than the spring rate of the Schnorr or Belleville washer. The waser compresses first, then the bolt shank stretches and establishes clamp load. So what does the Schnorr washer do differently? The design of the Schnorr washer helps provide some resistance to the fastener losing clamp load due to vibration acting to loosen the fastener. The Schnorr teeth "bite" into the base metal and the higer coefficient of friction in the counter clockwise direction helps prevent the fastern from loosening counter clockwise. Beyond that, I'd areee that a Schnorr acts just like a Belleville washer. In the end, neither will make up for not properly tightening the fastener using a torque wrench. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:26 PM |
