Cooling a 2.7l Type 4 easier/harder/same as a 2.7L flat six? |
Tdskip |
Aug 7 2020, 12:30 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Only a slightly theoretical question at this point – is there anything inherently different, or different in practice, between the oil cooling set up needed to keep a 2.7 L flat six cool versus the same displacement 2.7 L big Type 4?
It would seem like the flat six would have smaller displacement per cylinder and that might have less heat and more cooling fin surface area? Kind of an interesting topic I think / hope. Happy Friday. |
brant |
Aug 7 2020, 12:56 PM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
is the 4cylinder going to be a dry sump motor?
and stock -4 cylinder type cooling fan? a lot different my years of experience with both motors tells me the 4 is going to run hotter... the design, bearings, and complete "system" was for a lower output motor where as the -6 was designed for that displacement and was factory engineered to handle that heat better |
mepstein |
Aug 7 2020, 01:16 PM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
is the 4cylinder going to be a dry sump motor? and stock -4 cylinder type cooling fan? a lot different my years of experience with both motors tells me the 4 is going to run hotter... the design, bearings, and complete "system" was for a lower output motor where as the -6 was designed for that displacement and was factory engineered to handle that heat better Dry sump oil system, more outer cylinder surface area. Especially once they went from 5 blade to 11 blade fan. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:24 AM |
