Cooling a 2.7l Type 4 easier/harder/same as a 2.7L flat six? |
Tdskip |
Aug 7 2020, 12:30 PM
Only a slightly theoretical question at this point – is there anything inherently different, or different in practice, between the oil cooling set up needed to keep a 2.7 L flat six cool versus the same displacement 2.7 L big Type 4?
It would seem like the flat six would have smaller displacement per cylinder and that might have less heat and more cooling fin surface area? Kind of an interesting topic I think / hope. Happy Friday. |
Tdskip |
Aug 8 2020, 09:23 AM
@superhawk996 - very helpful, thanks.
I suppose at some point you just have to try it but wondering if even with keeping the oil cool via one of the cooler set ups if more cooling for fins is still required. As I bought it there as no rain tray and it had a larger grill area. |
Superhawk996 |
Aug 8 2020, 09:41 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
@superhawk996 - very helpful, thanks. I suppose at some point you just have to try it but wondering if even with keeping the oil cool via one of the cooler set ups if more cooling for fins is still required. As I bought it there as no rain tray and it had a larger grill area. If I recall your big bore engine already had aluminum cylinders. The aluminum cylinder will have far better heat transfer than cast iron. Since for all practical purposes you can't add more cylinder cooling fins, that leaves the following options: 1) More and/or cooler air for cooling which has a bounded limit. 2) More oil cooling. But given that oil has a better heat transfer coefficient than air, it will be the bigger knob. It too will be bounded at some point too. The upper bound to both #1 and #2 is what eventually forced Porche to water cooling. |
Lo-Fi Version | Time is now: 15th May 2024 - 03:26 PM |
