914 2.0 throttle position sensor rebuild ? TPS |
PotterPorsche |
Aug 11 2020, 11:45 AM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Is anyone still doing these ? I have shop that is looking to have there 2.0 throttle body rebushed .
Feel free to text or email Iscpotter@yahoo.com Or my cell phone 6502960926 |
Nojoah |
Aug 11 2020, 11:57 AM
Member Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
Is anyone still doing these ? I have shop that is looking to have there 2.0 throttle body rebushed . Feel free to text or email Iscpotter@yahoo.com Or my cell phone 6502960926 New TPS boards can be purchased now from 914 Rubber or a few other sources. I'm sure others will chime in. |
Mikey914 |
Aug 11 2020, 12:13 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep
It is a simple process to replace worn boards We have both 1.7 boards and the 2.0. Here’s a link to all the boards https://914rubber.com/search/?q=TPS Attached thumbnail(s) |
914sgofast2 |
Aug 11 2020, 02:28 PM
Senior Member Group: Members Posts: 616 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Yep It is a simple process to replace worn boards We have both 1.7 boards and the 2.0. Here’s a link to all the boards https://914rubber.com/search/?q=TPS He is asking for the throttle body bushings to be replaced, not the boards! |
brant |
Aug 11 2020, 02:31 PM
There is a guy in NM that does all of the different years of throttle bodies
I had mine done and his work is really top quality not cheap look in the vendor forum, he is in there nice guy too |
bdstone914 |
Aug 11 2020, 02:39 PM
The TPS does not get rebushed only the throttle body.
I had two 1.8 throttle bodies rebushed by a guy in AZ. I could look him up. Not sure of the cost as the customer paid the cost I just sold and shipped them. Might be easier to get a good used one. I have a few. I think there are two varients on ports. We also found some with no hole, or a different size hole in the throttle plate. Can you post pics of yours? @PotterPorsche |
DRPHIL914 |
Aug 12 2020, 07:56 AM
There is a guy in NM that does all of the different years of throttle bodies I had mine done and his work is really top quality not cheap look in the vendor forum, he is in there nice guy too i had mine done by Phil Eslin, he is the guy in NM, screen name is @Whip618 but he did a full clean, polish, new bushings all new shaft, butterfly valve, springs etc etc, and its better than new. Yes it was a bit pricey, i think about $350 2 years ago, but worth it in my opinion. if i can find a picture i will post it. but for my d-jet car, with this, a new TPS, new wire harness and rebuilt MPS from Jeff Bowlsby, and all new tin and heater bits from bdstone, and a 123ignition distributor, it runs like a new car. And if you want a good running 914 2.0 d-jet i think you have to do all these things. Phil |
DRPHIL914 |
Aug 12 2020, 08:17 AM
a couple pictures after the work was completed
DRPHIL914 |
Aug 12 2020, 08:18 AM
one more...
PotterPorsche |
Aug 12 2020, 09:24 AM
The shop needs the throttle body rebushed . They say it’s loose . Air bleeds by. Anyone have a phone number that they could pm . Or maybe a good used one with tight shaft within tolerances or spec ?
Lo-Fi Version | Time is now: 16th May 2024 - 01:41 PM |
