Valve Lash with Chrome Moly Pushrods? |
Charles Freeborn |
Aug 12 2020, 11:42 AM
Member Group: Members Posts: 250 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Title pretty much says it. What are you running for valve lash with Chrome Moly pushrods?
I've heard / read all sorts of numbers and theories. Some say that the steel rods don't expand at the rate the aluminum cases and heads do so you can run zero lash cold and it'll warm up to .06-8. Thx. |
wndsrfr |
Aug 14 2020, 06:50 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Title pretty much says it. What are you running for valve lash with Chrome Moly pushrods? I've heard / read all sorts of numbers and theories. Some say that the steel rods don't expand at the rate the aluminum cases and heads do so you can run zero lash cold and it'll warm up to .06-8. Thx. Yep..."loose zero" when cold.... there's a zen to it.... set it so you can just rotate the pushrod with your fingers... |
Lo-Fi Version | Time is now: 20th May 2024 - 11:26 PM |
