FS 912 E fuel injectors, 0 280 150 105 |
Krieger |
Aug 12 2020, 01:59 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I took these off an E in 91 with 95k miles. They have been in the garage since. Car was running great, but the owner wanted new parts. I tested them with a battery and the solenoids all work. I heard guys using L jet on bigger engines like these injectors since they flow more than the 1.8 injectors. $110 shipped flat rate.
JeffBowlsby |
Aug 12 2020, 05:01 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Their flow is actually 50% of what 2.0L D-Jet injectors flow. They are a good substitute for the 1.8L cars
bdstone914 |
Aug 13 2020, 07:53 PM
@JeffBowlsby
' date='Aug 12 2020, 04:01 PM' post='2842187'] Their flow is actually 50% of what 2.0L D-Jet injectors flow. They are a good substitute for the 1.8L cars [/quote] Jeff, Does the L jet use a longer pulse width to get as much fuel into the engine if the injector flow rate is half? |
JeffBowlsby |
Aug 13 2020, 09:52 PM
This is all I got.
Lo-Fi Version | Time is now: 17th May 2024 - 02:14 PM |
