> Injector Line Elbow, Fitment and MPS placement
trick-e
post Aug 14 2020, 05:53 AM
Still Learning
Fixing an injector seal leak, thought I’d replace the elbows. Always great stuff from 914 Rubber, so am wondering if they need to be shortened? They are quite a bit longer than the old ones, and have a sharper angle. The problem is they interfere with the MPS placement. If I try to make it work the elbows are pinched at the curve. Seems easy enough to cut off an inch or two, but that doesn’t seem right.
Thoughts?
914Sixer
post Aug 14 2020, 06:39 AM
Use your old cloth elbow as a pattern.
trick-e
post Aug 14 2020, 10:16 AM
Still Learning
Agreed. Just seems odd they’re not cut to size. Wondering if I had missed something. Thx
914Sixer
post Aug 14 2020, 02:57 PM
I had another thought about this. I am guessing you need the extra length to put the radius in the hose during manufacturing process.
Mikey914
post Aug 14 2020, 04:16 PM
The rubber man
You are correct.
Kind of like a universal hose you can cut to size.
trick-e
post Aug 14 2020, 07:15 PM
Still Learning
QUOTE(Mikey914 @ Aug 14 2020, 06:16 PM) *
You are correct.
Cut, in place, and we’ll fire it up tomorrow.
Thanks for the info.
trick-e
post Aug 28 2020, 02:29 AM
Still Learning
So, it was a leaking injector body, not the elbow. So I’ve a replacement injector, but need to exchange the cracked elbow. How should I remove the crimped fit while being gentle on the injector?
914Sixer
post Aug 28 2020, 06:16 AM
I used side cutters (dykes), others use dremel tool.
trick-e
post Aug 28 2020, 11:20 AM
Still Learning
Seemed seems obvious, at least now. Thx
- Lo-Fi Version Time is now: 13th January 2026 - 10:54 PM
