Harness connectors |
Archie |
Aug 14 2020, 01:23 PM
Member Group: Members Posts: 197 Joined: 23-September 09 From: Western Canada Member No.: 10,844 Region Association: Pacific Northwest |
Greetings Group!
Pulling the wiring harness, but I need some advice ...................AGAIN! Do these two white plastic connectors (Seatbelt sensors?) have to be disconnected to slide that branch wiring through the hole? Cap'n? Thanks in advance. Now on to drilling out the six massively rusted and sheared bolts that secured the underside of the rocker panel (one with a busted Easy-Out in it) !! Yum yum! Obviously the replacements will be stainless steel! |
914werke |
Aug 14 2020, 01:43 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
My recollection is no, you should be able to weasel one of the connectors out, then the next ect. but in any event they are easy to remove just use a jewelers screwdriver to depress the locking tap just be gentle so the tab can be bent back & reused
bkrantz |
Aug 14 2020, 09:21 PM
914 Guru Group: Members Posts: 7,762 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I got my harness out with the connectors attached.
Lo-Fi Version | Time is now: 15th May 2024 - 08:12 AM |
