Looking for hell hole welding advice |
AndrewBlyholder |
Aug 21 2020, 10:37 AM
Member Group: Members Posts: 109 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
More progress:
20 years ago, I totaled my previous street 914 in a front end accident (beware geriatric doctors in Cadillacs!) Put a deep vee in the nose that wrinkled everything back to the windshield posts. Let the insurance co. total the car, but bought the chassis back to strip it for parts. Cut up and tossed the bend chassis, but.... I did save the two back quarter panels thinking they might be useful for rust repair someday. Well, that day has come! The top size of the longitudinal was pretty rust pitted, but the bottom side was still pretty good. Here's the piece I cut out: Welded up all the holes I had to put into it to drill out the spot welds: Then made a cardborad template: Transferred the template to the part and cut it out (leaving about 1/8" extra all around.) My donor rear quarter was just a few inches short of where the rust ran to on the floor plan, so I had to fabricate and weld on an extension at the end: Here it is all nicely painted with weld-thru cold galzanizing paint: And finally, the patch fit into the hole: Today I'll start welding it back in! Andrew |
Aug 21 2020, 12:45 PM
Resident German Group: Admin Posts: 41,608 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Always good to see some progress, rust repair can be a daunting task.
(IMG:style_emoticons/default/smilie_pokal.gif) |
Krieger |
Aug 21 2020, 04:36 PM
Advanced Member Group: Members Posts: 4,704 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Awesome! That was the hard part!
IronHillRestorations |
Aug 21 2020, 04:53 PM
Looking good! I was concerned about the cracked inner mount, but it looks like you've changed course and headed in the right direction.
Cold galvanizing paint welds through very poorly. I'd suggest scratching or sanding off where you've got to weld. You don't want to breathe the zinc fumes it puts off either, it's bad news. I've used several brands and if you want to use weld through primer, UPol is the best. I still scratch off where I'm going to weld though, it makes it easier to strike an arc, especially if the metal has any thin spots. I'd suggest making some strategically placed holes and going back over your enclosed box sections with Eastwood's internal frame coating Eastwood Internal Frame coating I used a piece of welding rod (that I bent as needed) and taped the spray tube to it, to get in the box sections. Be sure and get their pre paint prep, you use it for purging the spray tube and nozzle. pre paint prep spray Of course it's a good product for prep cleaning. I did a total chassis (on a rotisserie) and it took about a dozen cans to do the whole car really good. |
Tdskip |
Aug 23 2020, 06:35 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Thanks for the updates.
@sirandy referred me to this link, providing it here as it is relevant to the work you are doing and may be helpful. http://www.914world.com/bbs2/index.php?showtopic=16748 In any case press on and good luck. |
AndrewBlyholder |
Aug 23 2020, 01:17 PM
Ok, here's the part where you learn by seeing other people's screw up.
First the lame excuse: I didn't bother with a door opening brace before starting this work because despite all the rust holes and cracks, the chassis had shown no signs of sagging. The passenger door was opening/closing fine with a normal panel gap that hadn't changed. And I was in a hurry of course to get the car back into operation for the next autocross. After getting my first big repair piece welded in - the inner half of longitudinal under the battery - I noticed that the door gap had opened up .1" at the top of the door. I had been worried about that gap closing down due to sag, but apparently the cooling shrinkage from all the welding had pulled the rear firewall/door jamb backwards. So off to the store to buy the biggest turn-buckle I could find and spent the afternoon fabricating a door brace: A 1/2" dia. turn-buckle, a couple of pieces of scrap angle iron, a couple 1/2" dia. bolts, and a fabricated 1/4" plate at the hinge mount. I went to the lower door hinge location rather than the top hinge because I didn't want to be flexing the front door jamb any. This way, when I tighten the brace, I should be just moving the rear jamb forwards. I measured across the top of the door opening before tightening the brace. Turning the turn-buckle to tighten the brace, I can decrease the top of the door opening by about 1/8" . That's enough to get my door panel gap back where it should be. But how much will it relax back after I'm done welding? I still have the outer half of the longitudinal to weld back into place. Will that stabilize it at the braced dimension, or will it still relax back some. If so, how much? Any advice out there? Andrew |
AndrewBlyholder |
Aug 23 2020, 01:28 PM
Thanks for the updates. @sirandy referred me to this link, providing it here as it is relevant to the work you are doing and may be helpful. http://www.914world.com/bbs2/index.php?showtopic=16748 In any case press on and good luck. Thanks, that's a good thread. Very much exactly what I'm doing. A big compromise I'm currently making is that I didn't want to remove the exterior fender. I very much consider what I'm doing now as a "temporary" repair. Eventually, I plan to do a better, concourse quality repair that I'm sure will require fully removing the exterior fender so that I can replace the longitudinal and the suspension consoles with new stampings. Andrew |
AndrewBlyholder |
Aug 23 2020, 01:33 PM
Another question: Am I crazy for doing this with gas welding? Is that making the shrinkage issue much worse? Should I go out and buy a MIG?
Doing the rosette welds in rusty, thin flanges is very frustrating with gas. So easy to overheat the flange and have it disintegrate in a flash. Often end up having to built it back, which takes a lot of heat. I end up with a very large area of red hot metal by the time I'm done. I'm getting better with each one, but still very tricky to do well. I'm assuming that a MIG will allow me to work much faster and therefore will less heat in the panel. Andrew |
Aug 23 2020, 02:59 PM
I'd use a MIG
Superhawk996 |
Aug 23 2020, 03:36 PM
914 Guru Group: Members Posts: 5,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Before you go buy a MIG. Try a smaller tip.
Too much heat and burn though is usually a sign that you can go down a size or two on the tip. Likewise, make sure you're not running more than a couple of PSI of gas pressure. The pressure of the gas coming out the tip will tend to blow your puddle though on the thin stuff. People underestimate what can be done with OxyAcetylene. It welded up many war birds back in the day before MIG and TIG came into thier own. A torch can weld thin gauge aluminum (with flux) and will often have better penetration and will actually visually blend the weld better than either TIG or MIG. A good welder with the right setup can do amazing things with a torch. However, when it's all said and done, MIG is faster and easier to learn. |
AndrewBlyholder |
Aug 28 2020, 11:51 AM
Ok, been so busy working on this trying to get the car put back together for the autocross this weekend I wasn't taking any time out to post. But the autocross has now been cancelled due to the wild fires around here, so I can slow down a bit and provide some updates.
This corner of the car had already seen some rust repair sheet metal replacement. Among other things, they cut away the top of the outer half of the longitudinal in the area under the battery and welded in a patch, but they only patched half of the whole opened up. They left a big hole in the top of the longitudinal at the low point next to the fire wall: Maybe they thought they were leaving a nice big drain hole, but that hole drains into the interior of the longitudinal tube! The tube also has small drain holes in it's bottom, but as as a enclosed area, it will be very slow to dry out. And indeed, I'm now fixing the rust this situation caused. So here's my patch to close the hole: Did it as a spot weld rather than continuously welded. Will make it watertight with seam sealer. Where the battery tray attached to the vertical inner fender wall was also completely corroded away. Cut out the bad part and laid it on my new stamping from AA to trace for the replacement patch: And here's the patch clamped in place: Love these panel clamps. Another great Harbor Freight buy! Here it is welded back in: And just because I'm anal retentive, I ground down all my functional but horrible looking welds and smoothed everything out with a quick swipe of body putty: Spot welded a new battery tray support into place, then coated everything with two coats of Por-15, then applied Wurth brushable seam sealer to all the seams that needed to be sealed: A close up of the seam sealer at the low point patch: The last job is now to patch the outer half of the longitudinal. I did all this work on the upper side of the longitudinal first because I didn't want anything falling into an already sealed up longitudinal. Now that all the top side, engine bay work it done, I can brush and vacuum out the inside of the longitudinal and be assured that it's pretty clean before sealing it up by welding on the outer half patch. My outer patch was also cut from the same AA stamping I used for the battery tray fender wall patch. But fitting it into place, it became clear that the stamping didn't exactly match my car, so I had to modify it: And here's the part after welding in a patch for the split. Also welded on the jack tube because once this is in place, there would be no way for me to get a torch tip on the top side of the tube: And here it is, welded into place and the welds ground down flat: Now, how do you get the outer jack tube reinforcement plate on? I couldn't put it on the patch before welding the patch because it would have covered over the patch's edge that needed to be welded. And I couldn't have made the patch bigger to move it's edge up above the jack reinforcement because then I couldn't have reached it with the outer fender in place. So this was my solution: I cut the reinforcement plate into two pieces, threaded the upper half on, and then I'll weld the lower portion back together. Got it screwed into place temporarily but didn't have time to weld it last night. That's where I pick up today. Andrew |
AndrewBlyholder |
Aug 28 2020, 12:04 PM
Before you go buy a MIG. Try a smaller tip. Too much heat and burn though is usually a sign that you can go down a size or two on the tip. Likewise, make sure you're not running more than a couple of PSI of gas pressure. The pressure of the gas coming out the tip will tend to blow your puddle though on the thin stuff. People underestimate what can be done with OxyAcetylene. It welded up many war birds back in the day before MIG and TIG came into thier own. A torch can weld thin gauge aluminum (with flux) and will often have better penetration and will actually visually blend the weld better than either TIG or MIG. A good welder with the right setup can do amazing things with a torch. However, when it's all said and done, MIG is faster and easier to learn. Totally agree with you about the versatility of gas welding. Have you heard of Kent White? He's a big proponent of gas welding and particularly for aluminum. He worked at the Harrah's car collection in Reno for many years, restoring vintage race cars and such, and then after that was sold off and split up, he's moved into the Warbird airplane restoration area. He's a genius aluminum welder and fabricator. I've seen him several times doing lectures at the EAA Air Venture fly-in at Oshkosh. An inspiring craftsman. I did manage to borrow a MIG welder from a friend. Unfortunately, it wasn't feeding the wire smoothly and consistently, so it's hard to make good looking beads with it, but even with that issue, it's much better for getting a spot weld on with minimal heating of the panel. After a day of tolerating the feed problem, I then took the time to look at the wire feed roller and found it was slipping on it's drive shaft. Tightened down it's attachment bolt and it seems to be working much better now. Now only some of my beads look like shit instead of all of them. (IMG:style_emoticons/default/laugh.gif) Andrew |
Superhawk996 |
Aug 28 2020, 04:32 PM
Have you heard of Kent White? He's a big proponent of gas welding and particularly for aluminum. He worked at the Harrah's car collection in Reno for many years, restoring vintage race cars and such, and then after that was sold off and split up, he's moved into the Warbird airplane restoration area. He's a genius aluminum welder and fabricator. I've seen him several times doing lectures at the EAA Air Venture fly-in at Oshkosh. An inspiring craftsman. Andrew Yup, Agree - Kent's work is awesome. I bought a set of his special lenses for welding aluminum with gas. They are pricey but worth every penny - you can really see the aluminum weld puddle clearly though the flux flare. His company TM Technologies also has some really awesome power hammers but they are way out of my price range. Maybe someday (IMG:style_emoticons/default/drooley.gif) https://www.tinmantech.com/about/kent-white-the-tin-man.php Cafe Racer gas welded tank I did a back around 2012 based on study of Kent's techniques, Ron Fournier Metal Fab book, and workshop that I attended that was given by one of Ron's former apprentices that now runs Voodoo Choppers. http://voodoochoppers.com/ Gas can do some awesome things. Never underestimate it! |
Krieger |
Aug 28 2020, 06:01 PM
Good job Andrew! (IMG:style_emoticons/default/beerchug.gif)
Tdskip |
Aug 29 2020, 07:06 AM
Nice work and thanks for the updates.
AndrewBlyholder |
Aug 29 2020, 11:33 AM
Have you heard of Kent White? He's a big proponent of gas welding and particularly for aluminum. He worked at the Harrah's car collection in Reno for many years, restoring vintage race cars and such, and then after that was sold off and split up, he's moved into the Warbird airplane restoration area. He's a genius aluminum welder and fabricator. I've seen him several times doing lectures at the EAA Air Venture fly-in at Oshkosh. An inspiring craftsman. Andrew Yup, Agree - Kent's work is awesome. I bought a set of his special lenses for welding aluminum with gas. They are pricey but worth every penny - you can really see the aluminum weld puddle clearly though the flux flare. His company TM Technologies also has some really awesome power hammers but they are way out of my price range. Maybe someday (IMG:style_emoticons/default/drooley.gif) https://www.tinmantech.com/about/kent-white-the-tin-man.php Cafe Racer gas welded tank I did a back around 2012 based on study of Kent's techniques, Ron Fournier Metal Fab book, and workshop that I attended that was given by one of Ron's former apprentices that now runs Voodoo Choppers. http://voodoochoppers.com/ Gas can do some awesome things. Never underestimate it! Beautiful!! |
AndrewBlyholder |
Aug 29 2020, 11:45 AM
Forgot to include in my last update the status of the door opening - Success!!
When I started, the door gaps at the rear of the door were .15" at the bottom and .20" at the top. After the first round of welding on the inner long. patch, the top gap had widened out to .30". That's when I realized I had a problem and installed the door brace. Tightening down on the door brace, I was able to close up the dimension across the top of the door by .20" That should have reduced my top door gap to .10". I figured I needed to go a bit beyond my target value of .15" because I expected, even with the brace now in place, that it would relax back a bit when I removed the tension on the brace. All done with the longitudinal repairs now, took the brace off and reinstalled the door. Top and bottom gaps are now .15". Whohoo! Ended up better than when I started. Nothing like dumb luck! (IMG:style_emoticons/default/piratenanner.gif) |
AndrewBlyholder |
Oct 20 2020, 12:30 PM
Just to finish off this thread, thought I'd post some final beauty shots of the finished product...
Engine compartment view of new battery support and tray, fender wall behind the battery tray patched, inner face of longitudinal frame between heating duct and engine mount patched, inner trailing arm ear cracks welded. Outer view of patched longitudinal frame with new jack point gusset and new rocker jack tube. (Disclaimer: previous owners replaced the inner and outer trailing arm consoles, so all the crappy, lumpy welding around those is NOT ME. Didn't take the time to grind all that away. As bad as it looks, its seems to be holding up ok. A future project...) Before all this work, the targa top squeaked horribly. Have only been driving the car fairly short distances around town lately so that problem hadn't risen to the top of the to-do list yet. But now, those squeaks have mostly disappeared!! (IMG:style_emoticons/default/idea.gif) Hmmm...perhaps the chassis is flexing a bit less now! So glad to have this done and over with!!! Andrew |
AZBanks |
Oct 20 2020, 02:22 PM
Senior Member Group: Members Posts: 1,058 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Nice work. It looks good.
Superhawk996 |
Oct 20 2020, 05:25 PM
(Disclaimer: previous owners replaced the inner and outer trailing arm consoles, so all the crappy, lumpy welding around those is NOT ME. Didn't take the time to grind all that away. As bad as it looks, its seems to be holding up ok. A future project...) Andrew (IMG:style_emoticons/default/happy11.gif) That's what I'm going to tell eveyone too after I'm done. (IMG:style_emoticons/default/av-943.gif) Seriously. You did a great job and tackled work that many won't take on! Keep an eye on it especially if you go back to AX'ing. |
Lo-Fi Version | Time is now: 1st May 2024 - 05:40 AM |
