Can i make this gauge work?, 911 gauge on a /4 |
Aaron Cox |
Jul 19 2003, 09:50 PM
i want to know if i can get the vdo dual sender to work with this gauge? if not- can i retrofit it?
Qarl |
Jul 19 2003, 10:28 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Somewhere out there on the net is a list of which 911 gauge corresponds with which sensor.
Can someone post a link? Now if it will fit in the 4 cylinder, I am not sure... Regards, Karl Ellzey |
Qarl |
Jul 19 2003, 10:35 PM
Maybe it was in UpFixen Der Porsche?
Can anybody look? |
KaptKaos |
Jul 19 2003, 11:53 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Problem is that you lose your gas gauge (if your going to put this left of the tach).
There a guy, can't find the link now, that builds a combo gauge with all the senders. Its like $500! - Joe |
bernbomb914 |
Jul 20 2003, 12:19 AM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I put a guage like that in my car, took out the clock and put in a VDO gas guage in its spot then put a head temp guage where the old oil temp. guage was. everything works great.
Bernie (IMG:style_emoticons/default/driving.gif) |
seanery |
Jul 20 2003, 07:48 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,841 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Pellican Parts used to sell a combo guage kit that had everything you need.
Called it a 904? It's NLA. |
ein 6er |
Jul 20 2003, 07:59 AM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
don't know if this will help.
doug Attached image(s) |
Qarl |
Palo Alto Speedometer sells the triple combo gauge and adapters for $425
I have one on order http://www.paspeedo.com |
Qarl |
Jul 20 2003, 08:00 AM
Thanks Doug! That's what I was looking for!
Karl |
Aaron Cox |
Jul 20 2003, 12:00 PM
yes- but that doesnt deal with 4 cylinder cars- and i was gonna do the same in my console bernbomb-
Joe Bob |
Jul 20 2003, 12:12 PM
QUOTE(kellzey @ Jul 20 2003, 05:59 AM) Palo Alto Speedometer sells the triple combo gauge and adapters for $425 I have one on order http://www.paspeedo.com 425 for a gauge.....geez, come with a bar of soap...? (IMG:style_emoticons/default/unsure.gif) |
Qarl |
Jul 20 2003, 02:14 PM
Yep $425 for the f-ing gauge. North Hollywood wants about $100 more.
But I figure that the triple gauge kit that Pelican had was about $125 plus $50 to $75 for the gauges needed for the kit plus $50-$60 for the correct senders. You're at $200 to $250 and then the time/labor needed to put the damn kit together. I tried the kit a few years ago and f-ed up one of the gauges I used and had to find another. And I don't have the right crimper for the bezel... blah blah! The gauge they make uses all new components (not the normal combo and fuel gauge modules)... blah blah! But, I'm also getting some custom coloring stuff done as well. Bend over is right! (IMG:style_emoticons/default/bootyshake.gif) |
cgnj |
Jul 20 2003, 02:33 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I will have a list of the gauges and the senders that are required for each. I will publish it and post a link. That guage should work. I went to the 904 style gauge and built it myself. $425 for the gauge and senders is worth it. I have a gas gauge that you could install in a center console that I no longer need.
Carlos 76 2270 'I could have had a flat six' 76 project |
Joe Bob |
Jul 20 2003, 02:42 PM
Geez.....I sent three gauges to them....had them white face em, recalibrate the speedo, put a different range on the tach....400 bucks. Dude, they be hosing ya......
Is that a gauge outright? Or did you ask what the price was to convert what ya have.....? |
Qarl |
Jul 20 2003, 03:22 PM
It's not a gauge made from standard 911 and 914 gauges. It's an all new gauge (outright) made from new VDO modules. Even the housing is custom.
Here are pics... (IMG:http://www.paspeedo.com/photos/8red.jpg) (IMG:http://www.paspeedo.com/photos/9.jpg) |
Lawrence |
Jul 20 2003, 04:23 PM
QUOTE Geez.....I sent three gauges to them....had them white face em, recalibrate the speedo, put a different range on the tach....400 bucks. Dude, they be hosing ya...... North Hollywood Speedo? I talked to PA Speedo, to have my speedo and tach recalibrated, and new faces painted... they estimated 800.00. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Qarl |
Jul 20 2003, 04:32 PM
http://www.nhspeedometer.com/
http://www.paspeedo.com/ These are the most well known speedo shops. Check locally too! |
Lo-Fi Version | Time is now: 25th April 2024 - 02:06 PM |
