type 4 line bore, I need a line bore in tucson az. |
goobstine |
Aug 21 2020, 10:23 PM
Newbie Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
will a type 4 vanagon crank slip into a type 4 914 case?
will a 2.0 crank fit into a 1.7 case with out machining ? will a 200 mm flywheel and pressure plate that is made to fit type 4 crank work okay with 1.7 thru 2.0 ? will 215mm flywheel from bus be okay with 914 transmission ? bus crank has pilot bearing in shaft 914 has in flywheel how do i go about using bus crank in 914 engine thank you ! |
jd74914 |
Aug 27 2020, 12:02 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Try contacting the Jesco Reient (John). He built cutting fixtures to align-bore cases and has done quite a lot.
http://www.914world.com/bbs2/index.php?sho...=236879&hl= |
Lo-Fi Version | Time is now: 6th May 2024 - 02:30 PM |
